Wired Intelligent Edge
NetEdit 2.0.5 - validation always fails
  • 1.  NetEdit 2.0.5 - validation always fails
    Posted Jun 23, 2020 06:48 AM
    I have installed a licensed version of netedit 2.0.5, and imported my switches.
    When i try to edit the config i always receive an error "unexpected failure validating config"
    The actual config change is something basic like vlan name, or interface unshut.
    The same error occurs on several switches (all 8325) both single or multiple edit of switches.
  • 2.  RE: NetEdit 2.0.5 - validation always fails
    Posted Jun 24, 2020 02:27 AM
    Best way forward would be to open a case with support at https://asp.arubanetworks.com/
  • 3.  RE: NetEdit 2.0.5 - validation always fails
    MVP GURU
    Posted Jun 30, 2020 03:00 AM
    Do you have found the issue ?
  • 4.  RE: NetEdit 2.0.5 - validation always fails
    Posted Jun 30, 2020 03:23 AM
    TAC was unaware of this issue, they asked me to downgrade, but i prefer waiting for a fix (not in production yet). If it takes to long i will downgrade to a previous version.
    i will update when i have some news from TAC
  • 5.  RE: NetEdit 2.0.5 - validation always fails
    Posted Jul 07, 2020 05:09 AM
    Aruba ERT engineer worked on this case and confirmed the issue (Aruba 8325 on 10.04.0041 with Netedit 2.05).
    The issue is resolved in an unreleased firmware, i have tested it successfully with version 10.05.0001
    I know have asked if the problem could be resolved in 10.04.xx, and i am awaiting response.
  • 6.  RE: NetEdit 2.0.5 - validation always fails
    Posted Jul 16, 2020 10:19 AM
    Issue is fixed in version 10.04.3000
  • 7.  RE: NetEdit 2.0.5 - validation always fails
    MVP GURU
    Posted Jul 18, 2020 04:33 AM
    Thanks for feedback !
