Highlighted
Frequent Contributor I
NetEdit: trial or free?
Hi there,
I just downloaded NetEdit 1.1 and when installing can select a "Starter Pack" license. It allows 25 devices. From datasheet, this should be a trial license.
From what I could see, it doesn't seem to (technically) expire.
I wonder if I can use the Trial/Starter-Pack license forever legally.
Accepted Solutions
Highlighted
MVP Guru
Re: NetEdit: trial or free?
yes, NetEdit 2.0 as well.
View solution in original post
All Replies
Highlighted
MVP Guru Elite
Hi, it is "Free" with no supported and limited to 25 devices with release 1.x
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Will 2.0 still support that 25 devices free license?
Highlighted
MVP Guru
Highlighted
MVP Guru
That's great!
@vincent.giles: when NetEdit 2.0 will be available on ASP?
Highlighted
MVP Guru
Very shortly.
Highlighted
I'm also hoping to see NetEdit 2.0 out very soon :) We're wondering if we should get 2930 or 6300... for our use case (dynamic segmentation) they would be on par. Someone said 6300 is more like 3810 but with dynamic segmentation for us it's 2930 vs 6300 now :)
If NetEdit 2.0 is great and there will be lot's of NAE stuff in the next couple months 6300 would be really interesting... also if you can orchestrate EVPN from NetEdit that would really make a difference
Highlighted
MVP Guru
Highlighted
MVP Guru Elite
Yes but no yet release note :(
Highlighted
MVP Guru
@alagoutte You wanted NetEdit 2.0 Release Notes? you got it! ;-)
