Highlighted
Re: NetEdit: trial or free?
Is there a somekind of EVPN orchestrator available, or do you need to do it manually? Just quickly tried the new version and seems you can have the VXLAN tunnels on the network topology view but is there a way to create those from NetEdit too?
Or maybe even return some VSAs from ClearPass to dynamically assign port to a correct EVPN?
Highlighted
MVP Guru Elite
@parnassus wrote:
@alagoutte You wanted NetEdit 2.0 Release Notes? you got it! ;-)
Yes ! and there is a installation guide !
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Occasional Contributor I
Can this version orchestrate the ArubaOS-CX version .ova (Virtual.10.02.0010)?
Or only works with physical devices?
Highlighted
I think NetEdit uses the REST API to talk with the switches? I think .ova also has REST API available so it probably works?
Still in the progress of testing this myself so let me know if you manage to get it working :)
Highlighted
MVP Guru
Yes !
NetEdit perfectly works with OVA so that you can practice, self-train on NetEdit and CX OVA on virtualization environment.
