Folks,
I am new to aruba swicthes. I have configured a couple of aruba switches in area 0 ospf and i am seeing routes being removed and then added back in the routing table. I want to collect some logs in the switches or run debug on these switches. Can someone please tell me how to accomplishing logging and debugging on aruba switches please.
Here is the output from show version of the switch.also please can any one check if i have configured ospf correctly on a vsx enabled switch.
(c) Copyright 2017-2019 Hewlett Packard Enterprise Development LP
Version : TL.10.02.0050
Build Date : 2019-06-05 08:02:01 PDT
Build ID : ArubaOS-CX:TL.10.02.0050:949fdb775550:201906051447
Build SHA : 949fdb775550cec83d71f4c3595121a5c1253864
Active Image : primary
Service OS Version : TL.01.03.0008
BIOS Version : TL-01-0013
vsx
GLF-011007EOR-01# show version
ArubaOS-CX
GLF-011007EOR-01# show run
Current configuration:
!Version ArubaOS-CX TL.10.02.0050
hostname nnnn
u
vrf KEEPALIVE-EOR-A
ntp enable
ssh server vrf default
ssh server vrf mgmt
router ospf 50
router-id 10.16.14.15
redistribute connected
area 0.0.0.0
vlan 1
vlan 1664
name TXRSVT_FedPortGroup
vsx-sync
ip igmp snooping enable
vlan 1666
name TXRSVT_StoragePortGroup
vsx-sync
vlan 1668
name TXRSVT_StorePG
vsx-sync
vlan 1670
name TXRSVT_ManagementPG
vsx-sync
vlan 1680
name TORMGMT1680
vsx-sync
vlan 1682
name TXRSTORV1
vsx-sync
vlan 1690
name TXRMGMTINT
vsx-sync
vlan 1692
name TXRINFINT
vsx-sync
vlan 1694
name TXRAPPINT
vsx-sync
vlan 2668
name TXRESX
vsx-sync
vlan 2680
name TXRSERVEREGG
vsx-sync
spanning-tree config-name d0:67:26:a6:95:60
interface mgmt
no shutdown
ip dhcp
interface lag 100 multi-chassis
no shutdown
no routing
vlan access 2680
lacp mode active
lacp rate fast
qos trust dscp
spanning-tree root-guard
interface lag 112 multi-chassis
no shutdown
no routing
vlan trunk native 1680
vlan trunk allowed all
lacp mode active
lacp rate fast
qos trust dscp
interface lag 113 multi-chassis
no shutdown
no routing
lacp mode active
lacp rate fast
qos trust dscp
interface lag 114 multi-chassis
no shutdown
no routing
lacp mode active
lacp rate fast
qos trust dscp
interface lag 115 multi-chassis
no shutdown
no routing
lacp mode active
lacp rate fast
qos trust dscp
interface lag 116 multi-chassis
no shutdown
no routing
lacp mode active
lacp rate fast
qos trust dscp
interface lag 117 multi-chassis
no shutdown
no routing
lacp mode active
lacp rate fast
qos trust dscp
interface lag 118 multi-chassis
no shutdown
no routing
lacp mode active
lacp rate fast
qos trust dscp
interface lag 200 multi-chassis
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
qos trust dscp
interface 1/1/1
description GLF-FWCORP-01A ETH1/23
no shutdown
mtu 9198
lag 100
interface 1/1/2
description GLF-011007TOR1-01 1/1/51
no shutdown
lag 112
interface 1/1/3
description GLF-011007TOR2-01 1/1/51
no shutdown
lag 113
interface 1/1/4
description GLF-011007TOR3-01 1/1/51
no shutdown
lag 114
interface 1/1/5
description GLF-011007TOR4-01 1/1/51
no shutdown
lag 115
interface 1/1/6
description GLF-011007TOR5-01 1/1/51
no shutdown
lag 116
interface 1/1/7
description GLF-011007TOR6-01 1/1/51
no shutdown
lag 117
interface 1/1/8
description GLF-011007TOR7-01 1/1/51
no shutdown
lag 118
interface 1/1/30
no shutdown
vrf attach KEEPALIVE-EOR-A
ip address 10.16.0.109/30
interface 1/1/31
vsx-sync access-lists qos vlans
no shutdown
mtu 9198
qos trust dscp
no routing
vlan trunk native 1 tag
interface 1/1/32
no shutdown
lag 200
interface loopback 0
ip address 10.16.14.15/32
ip ospf 50 area 0.0.0.0
interface vlan1664
vsx-sync active-gateways policies
description Simplivity Federation
ip address 10.16.64.2/23
active-gateway ip 10.16.64.1 mac 00:00:00:00:16:80
ip pim-sparse enable
interface vlan1666
description Simplivity Storage
ip address 10.16.66.2/23
active-gateway ip 10.16.66.1 mac 00:00:00:00:16:80
interface vlan1668
description Simplivity Virtual 1
ip address 10.16.68.2/23
active-gateway ip 10.16.68.1 mac 00:00:00:00:16:80
interface vlan1670
description Simplivity Virtual 2
ip address 10.16.70.2/23
active-gateway ip 10.16.70.1 mac 00:00:00:00:16:80
interface vlan1680
ip address 10.16.80.2/23
active-gateway ip 10.16.80.1 mac 00:00:00:00:16:80
interface vlan1682
description Storage for Nimble production
ip address 10.16.82.2/23
active-gateway ip 10.16.82.1 mac 00:00:00:00:16:80
interface vlan1690
description OOB Management and ILO
ip address 10.16.90.2/23
active-gateway ip 10.16.90.1 mac 00:00:00:00:16:80
interface vlan1692
description Infrastructure Internal VMs for Domain Controllers and DNS
ip address 10.16.92.2/23
active-gateway ip 10.16.92.1 mac 00:00:00:00:16:80
interface vlan1694
description Applications Internal
ip address 10.16.94.2/23
active-gateway ip 10.16.94.1 mac 00:00:00:00:16:80
interface vlan2668
description ESXHost
ip address 10.16.168.2/23
active-gateway ip 10.16.168.1 mac 00:00:00:00:16:80
interface vlan2680
ip address 10.16.180.2/23
active-gateway ip 10.16.180.1 mac 00:00:00:00:16:80
vsx
inter-switch-link 1/1/31
role primary
keepalive peer 10.16.0.110 source 10.16.0.109 vrf KEEPALIVE-EOR-A
vsx-sync aaa copp-policy dns mclag-interfaces qos-global sflow snmp ssh static-routes time
router pim
enable
