It seems the air flow direction changes every generation. It was back to front, then front to back, side to side intake, now side to side exhaust with the 2930?
That's a new one on me. Is the a config for the 2930 to reverse direction and someone is playing a trick on me, or is this the preferred direction in the 2930? That air is being brought in through the opposite vented side, across the boards, and being exhausted through the fans?
Is there a whitepaper on this method being better than just using the fans to intake air, pushing it across the board, and through the opposite side vents like all previous models?
Very curious.
