I'd like to run port tunneled mode from our edge switches to our 7240xm mobility controllers. Unfortunately our edge switches are 2530Gs and don't support tunneled node.
So, my question is, if I uplink my edge switches to a 2930 and port tunnel on the 2930 uplink ports instead, will it work?
Is there any limit to the number of clients or mac addresses per tunnel?
I'm not too bothered about authentication, i'm mainly doing this for segregation at present.
(It would be great if I could just tunnel the whole VLAN on the 2930, but that doesn't seem to be possible.)
