I have 4 Aruba 2930F, two in VSF on one side, and the other two in VSF on the other side.
I connect both VSFs via two ports in LACP Static Trunk.
Eventually I have connection problems in one of the VSFs.
Apparently, for some reason it seems that the LACP trunks lose and reconnect.
Could someone tell me if it's a configuration problem or if it's a hardware problem?
I attach the logs of events and configuration of each one.
Log events:
I 12/11/19 06:40:02 00828 lldp: ST2-CMDR: PVID mismatch on port 1/10(VID
100)with peer device port 1/1(VID 10)(14401)
I 12/11/19 06:40:07 00828 lldp: ST2-CMDR: PVID mismatch on port 1/1(VID 10)with
peer device port 1/10(VID 100)(14405)
I 12/11/19 06:40:51 00828 lldp: ST2-CMDR: PVID mismatch on port 1/7(VID 70)with
peer device port Ethernet0/0/4(VID 101)(14398)
I 12/11/19 06:41:28 00828 lldp: ST2-CMDR: PVID mismatch on port 1/9(VID 90)with
peer device port Ethernet0/0/5(VID 102)(14406)
W 12/11/19 15:41:37 05220 activate: ST2-CMDR: Unable to resolve the Activate
server address device.arubanetworks.com.
I 12/11/19 17:49:04 00077 ports: ST2-CMDR: port 2/22 in Trk1 is now off-line
I 12/11/19 17:49:04 00079 ports: ST2-CMDR: trunk Trk1 is now inactive
I 12/11/19 17:49:04 00077 ports: ST2-CMDR: port 1/22 in Trk1 is now off-line
I 12/11/19 17:49:11 00077 ports: ST1-STBY: port 2/22 in Trk1 is now off-line
I 12/11/19 17:49:11 00079 ports: ST1-STBY: trunk Trk1 is now inactive
I 12/11/19 17:49:11 00077 ports: ST1-STBY: port 1/22 in Trk1 is now off-line
I 12/11/19 17:49:07 00435 ports: ST2-CMDR: port 1/22 is Blocked by LACP
I 12/11/19 17:49:07 00435 ports: ST2-CMDR: port 2/22 is Blocked by LACP
I 12/11/19 17:49:13 00435 ports: ST1-STBY: port 1/22 is Blocked by LACP
I 12/11/19 17:49:14 00435 ports: ST1-STBY: port 2/22 is Blocked by LACP
I 12/11/19 17:49:13 00078 ports: ST2-CMDR: trunk Trk1 is now active
I 12/11/19 17:49:13 00076 ports: ST2-CMDR: port 2/22 in Trk1 is now on-line
I 12/11/19 17:49:13 00076 ports: ST2-CMDR: port 1/22 in Trk1 is now on-line
I 12/11/19 17:49:19 00078 ports: ST1-STBY: trunk Trk1 is now active
I 12/11/19 17:49:19 00076 ports: ST1-STBY: port 2/22 in Trk1 is now on-line
I 12/11/19 17:49:20 00076 ports: ST1-STBY: port 1/22 in Trk1 is now on-line
I 12/11/19 17:50:39 00077 ports: ST2-CMDR: port 2/21 in Trk2 is now off-line
I 12/11/19 17:50:39 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
I 12/11/19 17:50:39 00077 ports: ST2-CMDR: port 1/21 in Trk2 is now off-line
I 12/11/19 17:50:46 00077 ports: ST1-STBY: port 2/21 in Trk2 is now off-line
I 12/11/19 17:50:46 00079 ports: ST1-STBY: trunk Trk2 is now inactive
I 12/11/19 17:50:46 00077 ports: ST1-STBY: port 1/21 in Trk2 is now off-line
I 12/11/19 17:50:41 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
I 12/11/19 17:50:41 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
I 12/11/19 17:50:47 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
I 12/11/19 17:50:48 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
I 12/11/19 17:50:47 00078 ports: ST2-CMDR: trunk Trk2 is now active
I 12/11/19 17:50:47 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
I 12/11/19 17:50:47 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
I 12/11/19 17:50:53 00078 ports: ST1-STBY: trunk Trk2 is now active
I 12/11/19 17:50:53 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
I 12/11/19 17:50:54 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
I 12/11/19 17:50:53 00077 ports: ST2-CMDR: port 2/21 in Trk2 is now off-line
I 12/11/19 17:50:53 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
I 12/11/19 17:50:53 00077 ports: ST2-CMDR: port 1/21 in Trk2 is now off-line
I 12/11/19 17:50:59 00077 ports: ST1-STBY: port 2/21 in Trk2 is now off-line
I 12/11/19 17:50:59 00079 ports: ST1-STBY: trunk Trk2 is now inactive
I 12/11/19 17:50:59 00077 ports: ST1-STBY: port 1/21 in Trk2 is now off-line
I 12/11/19 17:50:57 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
I 12/11/19 17:50:57 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
I 12/11/19 17:51:04 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
I 12/11/19 17:51:04 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
I 12/11/19 17:51:00 00078 ports: ST2-CMDR: trunk Trk2 is now active
I 12/11/19 17:51:00 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
I 12/11/19 17:51:00 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
I 12/11/19 17:51:07 00078 ports: ST1-STBY: trunk Trk2 is now active
I 12/11/19 17:51:07 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
I 12/11/19 17:51:07 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
I 12/11/19 17:51:09 00077 ports: ST2-CMDR: port 2/22 in Trk1 is now off-line
I 12/11/19 17:51:16 00077 ports: ST1-STBY: port 2/22 in Trk1 is now off-line
I 12/11/19 17:51:09 00079 ports: ST2-CMDR: trunk Trk1 is now inactive
I 12/11/19 17:51:09 00077 ports: ST2-CMDR: port 1/22 in Trk1 is now off-line
I 12/11/19 17:51:16 00079 ports: ST1-STBY: trunk Trk1 is now inactive
I 12/11/19 17:51:16 00077 ports: ST1-STBY: port 1/22 in Trk1 is now off-line
I 12/11/19 17:51:11 00435 ports: ST2-CMDR: port 2/22 is Blocked by LACP
I 12/11/19 17:51:12 00435 ports: ST2-CMDR: port 1/22 is Blocked by LACP
I 12/11/19 17:51:18 00435 ports: ST1-STBY: port 2/22 is Blocked by LACP
I 12/11/19 17:51:18 00435 ports: ST1-STBY: port 1/22 is Blocked by LACP
I 12/11/19 17:51:14 00078 ports: ST2-CMDR: trunk Trk1 is now active
I 12/11/19 17:51:14 00076 ports: ST2-CMDR: port 1/22 in Trk1 is now on-line
I 12/11/19 17:51:14 00076 ports: ST2-CMDR: port 2/22 in Trk1 is now on-line
I 12/11/19 17:51:21 00078 ports: ST1-STBY: trunk Trk1 is now active
I 12/11/19 17:51:21 00076 ports: ST1-STBY: port 1/22 in Trk1 is now on-line
I 12/11/19 17:51:21 00076 ports: ST1-STBY: port 2/22 in Trk1 is now on-line
I 12/11/19 17:51:18 00077 ports: ST2-CMDR: port 2/21 in Trk2 is now off-line
I 12/11/19 17:51:18 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
I 12/11/19 17:51:18 00077 ports: ST2-CMDR: port 1/21 in Trk2 is now off-line
I 12/11/19 17:51:24 00077 ports: ST1-STBY: port 2/21 in Trk2 is now off-line
I 12/11/19 17:51:24 00079 ports: ST1-STBY: trunk Trk2 is now inactive
I 12/11/19 17:51:24 00077 ports: ST1-STBY: port 1/21 in Trk2 is now off-line
I 12/11/19 17:51:20 00435 ports: ST2-CMDR: port 2/22 is Blocked by LACP
I 12/11/19 17:51:20 00435 ports: ST2-CMDR: port 1/22 is Blocked by LACP
I 12/11/19 17:51:20 00079 ports: ST2-CMDR: trunk Trk1 is now inactive
I 12/11/19 17:51:20 00002 vlan: ST2-CMDR: VL 80 virtual LAN disabled
I 12/11/19 17:51:27 00435 ports: ST1-STBY: port 2/22 is Blocked by LACP
I 12/11/19 17:51:27 00435 ports: ST1-STBY: port 1/22 is Blocked by LACP
I 12/11/19 17:51:27 00079 ports: ST1-STBY: trunk Trk1 is now inactive
I 12/11/19 17:51:21 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
I 12/11/19 17:51:21 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
I 12/11/19 17:51:28 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
I 12/11/19 17:51:28 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
I 12/11/19 17:51:22 00078 ports: ST2-CMDR: trunk Trk1 is now active
I 12/11/19 17:51:22 00076 ports: ST2-CMDR: port 1/22 in Trk1 is now on-line
I 12/11/19 17:51:22 00001 vlan: ST2-CMDR: VL 80 virtual LAN enabled
I 12/11/19 17:51:29 00078 ports: ST1-STBY: trunk Trk1 is now active
I 12/11/19 17:51:29 00076 ports: ST1-STBY: port 1/22 in Trk1 is now on-line
I 12/11/19 17:51:23 00076 ports: ST2-CMDR: port 2/22 in Trk1 is now on-line
I 12/11/19 17:51:24 00078 ports: ST2-CMDR: trunk Trk2 is now active
I 12/11/19 17:51:24 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
I 12/11/19 17:51:24 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
I 12/11/19 17:51:30 00076 ports: ST1-STBY: port 2/22 in Trk1 is now on-line
I 12/11/19 17:51:31 00078 ports: ST1-STBY: trunk Trk2 is now active
I 12/11/19 17:51:31 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
I 12/11/19 17:51:31 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
I 12/11/19 17:53:43 00077 ports: ST2-CMDR: port 2/21 in Trk2 is now off-line
I 12/11/19 17:53:43 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
I 12/11/19 17:53:43 00077 ports: ST2-CMDR: port 1/21 in Trk2 is now off-line
I 12/11/19 17:53:50 00077 ports: ST1-STBY: port 2/21 in Trk2 is now off-line
I 12/11/19 17:53:50 00079 ports: ST1-STBY: trunk Trk2 is now inactive
I 12/11/19 17:53:50 00077 ports: ST1-STBY: port 1/21 in Trk2 is now off-line
I 12/11/19 17:53:46 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
I 12/11/19 17:53:46 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
I 12/11/19 17:53:52 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
I 12/11/19 17:53:52 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
I 12/11/19 17:53:49 00078 ports: ST2-CMDR: trunk Trk2 is now active
I 12/11/19 17:53:49 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
I 12/11/19 17:53:49 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
I 12/11/19 17:53:55 00078 ports: ST1-STBY: trunk Trk2 is now active
I 12/11/19 17:53:55 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
I 12/11/19 17:53:55 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
I 12/11/19 17:53:58 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
I 12/11/19 17:53:58 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
I 12/11/19 17:53:58 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
I 12/11/19 17:54:05 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
I 12/11/19 17:54:05 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
I 12/11/19 17:54:05 00079 ports: ST1-STBY: trunk Trk2 is now inactive
I 12/11/19 17:54:00 00078 ports: ST2-CMDR: trunk Trk2 is now active
I 12/11/19 17:54:00 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
I 12/11/19 17:54:06 00078 ports: ST1-STBY: trunk Trk2 is now active
I 12/11/19 17:54:06 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
I 12/11/19 17:54:01 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
I 12/11/19 17:54:08 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
VSF 1 config
Running configuration:
; hpStack_WC Configuration Editor; Created on release #WC.16.04.0014
; Ver #11:10.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:bc
hostname "Core-HV-Commander"
vsf
enable domain 9000
member 1
type "JL259A" mac-address 9cdc71-37da40
priority 255
link 2 1/23-1/24
link 2 name "I-Link1_2"
exit
member 2
type "JL259A" mac-address 9cdc71-362fe0
priority 128
link 2 2/23-2/24
link 2 name "I-Link2_2"
exit
port-speed 1g
exit
aruba-central disable
trunk 1/1-1/2,2/1-2/2 trk1 lacp
trunk 1/3-1/4,2/3-2/4 trk2 lacp
trunk 1/5-1/6,2/5-2/6 trk3 lacp
trunk 1/7-1/8,2/7-2/8 trk4 lacp
trunk 1/9,2/9 trk5 lacp
trunk 1/10,2/10 trk6 lacp
trunk 1/21,2/21 trk50 lacp
trunk 1/22,2/22 trk60 lacp
include-credentials
password manager user-name "manager" sha1
"6f2f6aad0e3d08acaa56fcae9ead3eb7ad259ed6"
time timezone -3
interface 1/1
lacp key 100
exit
interface 1/2
lacp key 100
exit
interface 1/3
lacp key 200
exit
interface 1/4
lacp key 200
exit
interface 1/5
lacp key 300
exit
interface 1/6
lacp key 300
exit
interface 1/7
lacp key 400
exit
interface 1/8
lacp key 400
exit
interface 1/9
lacp key 500
exit
interface 1/10
lacp key 600
exit
interface 1/11
lacp key 700
exit
interface 1/22
lacp key 9999
exit
interface 2/1
lacp key 100
exit
interface 2/2
lacp key 100
exit
interface 2/3
lacp key 200
exit
interface 2/4
lacp key 200
exit
interface 2/5
lacp key 300
exit
interface 2/6
lacp key 300
exit
interface 2/7
lacp key 400
exit
interface 2/8
lacp key 400
exit
interface 2/9
lacp key 500
exit
interface 2/10
lacp key 600
exit
interface 2/11
lacp key 700
exit
interface 2/22
lacp key 9999
exit
snmp-server community "public" unrestricted
snmpv3 engineid "00:00:00:0b:00:00:9c:dc:71:37:da:43"
vlan 1
name "DEFAULT_VLAN"
untagged 1/11-1/20,1/25-1/28,2/11-2/20,2/25-2/28,Trk1-Trk6,Trk50,Trk60
ip address 10.250.250.16 255.255.255.0
exit
spanning-tree Trk1 priority 4
spanning-tree Trk2 priority 4
spanning-tree Trk3 priority 4
spanning-tree Trk4 priority 4
spanning-tree Trk5 priority 4
spanning-tree Trk6 priority 4
spanning-tree Trk50 priority 4
spanning-tree Trk60 priority 4
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
VSF 2 config
; hpStack_WC Configuration Editor; Created on release #WC.16.05.0007
; Ver #12:08.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:ba
hostname "Enlaces-Commander"
vsf
enable domain 9001
member 1
type "JL259A" mac-address 08f1ea-4a4020
priority 255
link 1 1/23-1/24
link 1 name "I-Link1_1"
exit
member 2
type "JL259A" mac-address 548028-6068e0
priority 128
link 1 2/23-2/24
link 1 name "I-Link2_1"
exit
port-speed 1g
exit
trunk 1/22,2/22 trk1 lacp
trunk 1/21,2/21 trk2 lacp
trunk 1/20,2/20 trk3 lacp
no timesync
time timezone -3
interface 1/3
speed-duplex 100-full
exit
interface 1/6
exit
interface 1/7
exit
interface 1/21
lacp key 533
exit
interface 1/22
lacp key 532
exit
interface 2/21
lacp key 533
exit
interface 2/22
lacp key 532
exit
snmp-server contact "Some user"
vlan 1
name "DEFAULT_VLAN"
no untagged 1/1-1/18
untagged 1/19,1/25-1/28,2/1-2/19,2/25-2/28,Trk1-Trk3
ip address 10.250.250.18 255.255.255.0
exit
vlan 10
name "VL 10"
untagged 1/1
tagged Trk1-Trk2
no ip address
exit
vlan 20
name "VL 20"
untagged 1/2
tagged Trk1-Trk2
no ip address
exit
vlan 30
name "VL 30"
untagged 1/3
tagged Trk1-Trk2
no ip address
exit
vlan 40
name "VL 40"
untagged 1/4
tagged Trk1-Trk2
no ip address
exit
vlan 50
name "VL 50"
untagged 1/5
tagged Trk1-Trk2
no ip address
exit
vlan 60
name "VL 60"
untagged 1/6
tagged Trk1-Trk2
no ip address
exit
vlan 70
name "VL 70"
untagged 1/7
tagged Trk1-Trk2
no ip address
exit
vlan 80
name "VL 80"
untagged 1/8
tagged Trk1-Trk2
no ip address
exit
vlan 90
name "VL 90"
untagged 1/9
tagged Trk1-Trk2
no ip address
exit
vlan 100
name "VL 100"
untagged 1/10
tagged Trk1-Trk2
no ip address
exit
vlan 110
name "VL 110"
untagged 1/11
tagged Trk1-Trk2
no ip address
exit
vlan 120
name "VL 120"
untagged 1/12
tagged Trk1-Trk2
no ip address
exit
vlan 130
name "VL 130"
untagged 1/13
tagged Trk1-Trk2
no ip address
exit
vlan 140
name "VL 140" untagged 1/14
tagged Trk1-Trk2
no ip address
exit
vlan 150
name "VL 150"
untagged 1/15
tagged Trk1-Trk2
no ip address
exit
vlan 160
name "VL 160"
untagged 1/16
tagged Trk1-Trk2
no ip address
exit
vlan 170
name "VL 170"
untagged 1/17
tagged Trk1-Trk2
no ip address
exit
vlan 180
name "VL 180"
untagged 1/18
tagged Trk1-Trk2
no ip address
exit
no tftp server
no autorun
Thank you very much for your help.,
Best regards,
Gabriel
