Highlighted
Occasional Contributor I
RAP Wired Port 802.1X
Hi All,
I'm configuring a RAP and I've assigned the RAP wired port to an AAA profile, with 802.1X. I've then got a switch connected into the RAP port, with users connecting into the switch.
Do I also need to enable untrusted on this? For some reason, when my test clients are connecting they're being sent to a captive-portal page?
Accepted Solutions
Highlighted
MVP Expert
Re: RAP Wired Port 802.1X
Need to switch to untrusted
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
View solution in original post
All Replies
Highlighted
MVP Expert
How’s the RAP port and AAA profile to switch configured ?
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Highlighted
I have the switch configured as an access link from switch to RAP (all users on the same VLAN), the AAA profile is configured under the L2 Authentication section in Managed Network, and assigned to the AP Profile Wired Port AAA profile
AAA profile has initial role of logon, and 802.1x authentication default role as authenticated?
Highlighted
MVP Expert
Is the wired ap profile set to untrusted ?
Thank you
Victor Fabian
Highlighted
It is currently set to trusted at the moment?
Highlighted
MVP Expert
Thank you
Victor Fabian
Highlighted
Thanks Fabian! Worked! :)
