Greetings!
With the release of the Aruba 8325 core and data center switch, we have made a minor revision to our 2-post and 4-post rack kits to accommodate a slight change in the mounting hole patterns on this switch family.
The revised 2-post (JL482B) and 4-post (JL483B) rack kits are compatible with both the 8325 and 8320 switch families, while the kits they replaced (JL482A and JL483A) are compatible only with the 8320 series.
The two revised kits are pictured below:
JL482B Aruba X472 2-post Rack KitJL483B Aruba X474 4-post Rack Kit
Note: 8325 series switches do not include a rack mount kit in the box; either a 2-post or 4-post kit must be ordered separately. Switches in the 8320 series will continue to include a 2-post kit in the box.
