Hi chaps,
I have got an Aruba 5405 switch with the following SNMPv3 configuration:
snmp-server enable traps startup-config-change
snmp-server enable traps running-config-change
snmpv3 enable
snmpv3 only
snmpv3 restricted-access
snmpv3 group managerpriv user "initial" sec-model ver3
snmpv3 notify "initial" tagvalue "initial"
snmpv3 targetaddress "initial" params "initial" 192.168.1.203 filter all taglist "initial"
snmpv3 params "initial" user "initial" sec-model ver3 message-processing ver3 priv
snmpv3 community index "initial" name "initial" sec-name "initial" tag "initial"
snmpv3 user "initial"
Within Airwave, I have added the switch to it, with the correct SNMP and SSH credentials. Airwave is able to collect the device information.
The issue is, Airwave can't receive any SMNP traps.
Could someone point out if anything else I will need to do?
NC
