I would like to verify my assumption regarding the below scenario.
In an environment with a 2-switch Mesh (switch A(commander) and B(standby)) of 3810M series switch.
If Switch A fails, my assumption is that, the stack configuration remains with switch B and when I replace switch A with switch C,
the stack doesn't split. That is, Switch B becomes the commander and copies to the configuration files to the new switch C.
Is this right?
If wrong, please educate me.
Thank you.
obi jessie
Original Message:
Sent: May 15, 2019 06:25 AM
Subject: Stacking switches
Yes, HPE OfficeConnect 1950 Switch series (which is based on Comware 7 and not on ArubaOS-Switch as cited Aruba Switch series) provides IRF technique which is powerful enough for your desired scenario (Pay attention that 1950 user guide uses the term "Stacking" hiding the fact that - de facto - that implementation is basically the same IRF technique used on low-/mid-/high-end DC class switch series of HPE).
