Wired Intelligent Edge
Swap a 2930F switch of a VSF stack
  • 1.  Swap a 2930F switch of a VSF stack
    Posted Aug 08, 2019 10:45 AM
    Hi all,
    We have 2 Aruba Switches in stack. The problem is that we need to replace one of them.
    Switch# sh vsf
    VSF Domain ID : 1
    MAC Address :
    VSF Topology : Chain
    VSF Status : Active
    Uptime : 28d 21h 43m
    VSF MAD : None
    VSF Port Speed : 1G
    Software Version : WC.16.08.0003
    Mbr
    ID MAC Address Model Pri Status
    1 XXXXXXXXXXXXX Aruba JL261A 2930F-24G-PoE+-4SFP S... 128 Standby
    2 XXXXXXXXXXXXXX Aruba JL261A 2930F-24G-PoE+-4SFP S... 128 Commander
    We have to replace the 1 member. I have read some information but I want to be sure which is the best precedure to do the replacing.
    - Do we have to configure the new unit? Or If it's in factory config it's OK?
    -Do we have to stop the second unit when we form the stack?
    - Is there any manual to do this step by step?
    Many thanks in advance.
    Best regards,
    Roger
  • 2.  RE: Swap a 2930F switch of a VSF stack
    Posted Aug 08, 2019 12:57 PM
    You can find those steps here in the Management and Config Guide:
    http://h22208.www2.hpe.com/eginfolib/Aruba/16.09/5200-5906/index.html#GUID-CD2414D8-E631-45B8-9DF4-F5A491396410.html
    Justin
  • 3.  RE: Swap a 2930F switch of a VSF stack
    Posted Aug 09, 2019 06:31 AM
    Many thanks for your prompt answer. If I have more questions I will let you know.
  • 4.  RE: Swap a 2930F switch of a VSF stack
    Posted Aug 09, 2019 06:35 AM
    Just a short question.
    The new switch which is in factory config, has to be in the same version as the other switch that are working in the stack? Or it will be automatically updated when we join to the stack
    Do we have to stop the other switchs during the swap or it's not necessary?
    Best regards,
    ROger
  • 5.  RE: Swap a 2930F switch of a VSF stack
    Posted Aug 09, 2019 10:28 AM
    lt will automatically upgrade to the code version of the commander.
    Justin
