Wired Intelligent Edge
Transfer configuration from Aruba 2530 to other Aruba 2530
  • 1.  Transfer configuration from Aruba 2530 to other Aruba 2530
    Posted Sep 12, 2018 03:07 AM
    How transfer all configuration (with local user account and SSL certyficate) from Aruba 2530 to other Aruba 2530 ?
    THX
  • 2.  RE: Transfer configuration from Aruba 2530 to other Aruba 2530
    MVP GURU
    Posted Sep 12, 2018 04:25 AM
    for local user, you need to add include-credentials on first switch to add command for local user
    for the certicate, it is a self signed ?
  • 3.  RE: Transfer configuration from Aruba 2530 to other Aruba 2530
    Posted Sep 12, 2018 05:14 AM
    "for the certicate, it is a self signed ?" Yes
  • 4.  RE: Transfer configuration from Aruba 2530 to other Aruba 2530
    MVP GURU
    Posted Sep 12, 2018 05:24 AM
    Need confirmation, but no found a way to export the certificate
  • 5.  RE: Transfer configuration from Aruba 2530 to other Aruba 2530
    Posted Sep 12, 2018 06:57 AM
    And so i'am must on other Aruba first create local user, create SSL certyficate and import config file from first Aruba ?
  • 6.  RE: Transfer configuration from Aruba 2530 to other Aruba 2530
    MVP GURU
    Posted Sep 12, 2018 07:12 AM
    Yes
  • 7.  RE: Transfer configuration from Aruba 2530 to other Aruba 2530
    Posted Sep 13, 2018 03:31 AM
    When import confi file on other Aruba by Web Interface -> Management -> Update and uplad new config file, aruba shwo this message "web-management: The specifited TCP/UDP port is in use by another protocol".
  • 8.  RE: Transfer configuration from Aruba 2530 to other Aruba 2530
    MVP GURU
    Posted Sep 13, 2018 09:16 AM
    Do you try to upload to startup config and reboot ?
