Hi all,
Question about vsf lldp-mad feature that require the V2c community_string option like:
vsf lldp-mad ipv4 xxx.xxx.xxx.xxx V2c public
What'happen if only SNMPv3 is enabled on my 2930f switches ?
Thanks for help.
JG.
if only snmpv3 is enabled, then snmpv2 will not work.
You can activate snmpv2 and assign acl, to allow access only by vsf stack. Additionally: Read only access should be enough.
Regards, JHH
