Wired Intelligent Edge
VSX for 8320 and OOBM port
  • 1.  VSX for 8320 and OOBM port
    Posted Mar 22, 2019 01:28 PM
    Hi community,
    When you virtualize 2 Aruba 8320 using VSX, what happens with each 10/100/1000Base-T RJ-45 Out-of-Band Management (OOBM) port?.
    Both are active simultaneously?, just one?, each one have a different IP address?.
    Can anybody explain me how they work during virtualization and what happens with them if both members of VsX splits?
    Regards
    #8320
  • 2.  RE: VSX for 8320 and OOBM port
    MVP GURU
    Posted Mar 22, 2019 04:12 PM
    VSX and VSX nodes' OoBM ports are independents.
    OoBM ports, as usual, should be configured with IP Addresses you plan to use for switch/network management (at least I did so) and then you can control each VSX member through the mgmt VRF which own, separately on each Aruba 8320, the OoBM port.
    Reference: Aruba 832x Fundamentals Guide for ArubaOS-CX 10.02 (Initial configuration -> Configuring the management interface).
    Basically look at OoBM port like having another logical "one-port switch" inside the Aruba 8320 which you connect to in order to manage (out-of-band) switch VRFs and any other Switch/VSX configuration.
