I am working through a lab to learn ArubaOS-CX. I have a VSX setup with 2 virtual CX VMs in GNS3. Everything looks to be healthy except I noticed that an item labeled NAE is peer_reachable on one box and peer_unreachable on the other. I don't have NAE (Network Analytics Engine) enabled or running anywhere unless it's on by default so not sure if that's the same acronym or refers to something different.
Is this something to be concerned with for VSX? Is this not relevant in my topology? Why would one say peer_reachable when I'm not running NAE? Any assistance is appreciated. Note, I've rebooted each box and the box which says peer_reachable doesn't stay consistent once everything is back up so not sure where else to look.
CXLAB-DIST01# show vsx status
VSX Operational State
ISL channel : In-Sync
ISL mgmt channel : operational
Config Sync Status : in-sync
NAE : peer_reachable
HTTPS Server : peer_reachable
Attribute Local Peer
ISL link lag256 lag256
ISL version 2 2
System MAC 02:01:00:00:01:00 02:01:00:00:01:00
Platform X86-64 X86-64
Software Version Virtual.10.04.1000 Virtual.10.04.1000
Device Role primary secondary
CXLAB-DIST01# show vsx status vsx-peer
NAE : peer_unreachable
ISL version 2 2
Device Role secondary primary
