Wired Intelligent Edge
technical and spec difference between JW811A and JW813A
  • 1.  technical and spec difference between JW811A and JW813A
    Posted Aug 29, 2018 05:15 PM
    Hello network gurus! Could you please explain the technical and spec difference between JW811A and JW813A? Are they the same in the sense of the hardware and software?
  • 2.  RE: technical and spec difference between JW811A and JW813A
    Posted Sep 05, 2018 04:00 AM
    The difference is the regulatory domains of these APs, as can be seen in the data sheet.
    *JW811A Aruba Instant IAP-315 (RW) 802.11n/ac Dual 2x2:2/4x4:4 MU-MIMO Radio Integrated Antenna AP
    *JW813A Aruba Instant IAP-315 (US) 802.11n/ac Dual 2x2:2/4x4:4 MU-MIMO Radio Integrated Antenna AP
    So the hardware and software are the same, but they are restricted in terms of the regulatory domain.
  • 3.  RE: technical and spec difference between JW811A and JW813A
    MVP GURU
    Posted Sep 05, 2018 04:52 AM
    Why somebody erased my (accepted as solution) post of August, 29th 2018?
  • 4.  RE: technical and spec difference between JW811A and JW813A
    Posted Sep 05, 2018 07:05 AM
  • 5.  RE: technical and spec difference between JW811A and JW813A
    MVP GURU
    Posted Sep 05, 2018 07:47 AM
    Pretty strange since I originally answered to OP with my post and then I forgot about it (never touched again as I recall)...only when I received the "Accepted as solution" tag I noticed I wasn't able to find it where it was.
