Highlighted
Moderator
Re: ?? boots as only AM mode.
The default AP group is set to air monitor out of the box. You will need to create a new ap group and add a virtual AP and then provision the AP into that group.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Re: AP boots as only AM mode.
According to the log, you either need to:
- approve that access point
Or
- disable control plane security.
Please see the chapter on Control Plane Security here:  http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Control_Plane/Configuring_Control_Plan.htm
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
Contributor I
Though I disabled cpsec, manualy approved and provisioned , the result was same.
Anyway I think ap should not goes to AirMonitor mode without any vap profile setting.
because default profile is ap-mode on each radio.
Highlighted
Is this your access point?
Dec 1 01:21:16 :305049:  <WARN> |stm|  Unsecure AP "ac:a3:1e:c2:99:aa" (MAC ac:a3:1e:c2:99:aa, IP 172.16.11.153) has been denied access because Control Plane Security is enabled and the AP is not approved.
 If the answer is "yes", it needs to be approved.  It can take from 8 to 10 minutes for the access point to boot and get a certificate the first time.
Highlighted
Contributor I
Yes, it's my ap , not a customer's.
Of course I tried to approve.
[Before]
CPsec : enabled
Auto Cert Provisioning : enabled
White list : approved-ready-for-cert
[After] ( few minuts later )
CPsec: enabled
White list : certified-factory-cert
And I did provisioning for ap but nothing changed.
Do you mean this as "it needs to be approved" ?
it goes slumming...
Highlighted
Please type "show log system 50" so we can see what the problem is.
If this is NOT a production network, I would just disable control plane security, and then reboot your access point with the problem.
Highlighted
Contributor I
I disabled cpsec.
Then, already certified ap couldn't connect tunnel to lms.
So I rebooted ap and oprerated purgeenv.
Then ap turned up and became AM mode again.
I attach log.
Thank you.
Highlighted
What is the output of "show ap database"
Highlighted
Contributor I
I'm so sorry to say that I have to lease this IAP to my customer, so I can't research about this in days... ( this ap acts as IAP correctly )
Woud you mind if I resume discussion at a later date ?
Highlighted
No problem
