Highlighted
Re: 30 students on 1 AP ?
There is an airtime fairness configuration that can mitigate that:  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#CLI_commands/arm.htm?Highlight=fairness
In most deployments, I am not sure that I even see that enabled, but it is there if you need it.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Hi Colin,
great to know, that, i can have a test with that
Highlighted
when talking with a reseller, i was told that ap 205 could be enought due to that student's laptop won't have latest wifi protocol and then won't take advantages of ap 315.
Cost is less than i could buy more 215 and have less device per ap
Is that correct ?
Highlighted
You should probably talk to your reseller about that, to make sure that you are making the right decision.
