Super Contributor II
Re: AOS 8.2 Captive portal issues
we're definitely using the right profile. the second one was created for another use case.
That was my thinking, but it sounds like the reference count for ClearPass lines up with your expected use count.
Do you have a mac or other device that you can grab a wireshark capture to see where the logout window is being triggered from?
Charlie Clemmer
Aruba Customer Engineering
I am having very similar issues with an 8.3.0.5 deployment. All configs pushed from the mobility master.
A few differences, everyone once and a while login is successful. When it is successful the logout window appears, even though it is unchecked.
Also, I have include switch IP in the URL. I imagine that it should show up as plain text in the URL as the rest of the information does, but it is not present.
Any Ideas?
unfortunately i was never able to get to the bottom of my issue as it was a temporary setup for a conference and i had to rip it out at the end.
