AOS 8.3.0.7 becomes to CR 3 weeks after it is released, is it possible?
  • 1.  AOS 8.3.0.7 becomes to CR 3 weeks after it is released, is it possible?
    Posted Jul 04, 2019 11:18 AM
    Hi All,
    Previously, I had a lot of problems with 8.3.x Standard Releases, so I used 8.2.x Conservative Releases.
    However I must install 8.3.x at one of our customer a few weeks ago because there were AP345 types in the network. I chose the version 8.3.0.1, the more it was the least known bug in the Release Note.
    Unfortunately, the customer ran into a problem. After debugging, we could see a known bug that was listed as a resolved issue in 8.3.0.1 Release Notes.
    It seems the fix is not perfect, so I want to upgrade the system, and I do not know that we dare to install the 8.3.0.7 version. 8.3.0.7 Release Notes contains 16 pages of known issues, so I have doubt about it.
    What do you think about this "early" Conservative Release?
    Thanks!
  • 2.  RE: AOS 8.3.0.7 becomes to CR 3 weeks after it is released, is it possible?
    Posted Jul 04, 2019 12:22 PM
    If your customer observed a bug that is fixed in 8.3.0.1, I hope you reported it, so it can get fixed.
    Also, I assume you also have read the article here?  https://community.arubanetworks.com/t5/Wireless-Access/Updates-to-Aruba-Release-Naming-Replacing-ED-and-GA/td-p/279651
  • 3.  RE: AOS 8.3.0.7 becomes to CR 3 weeks after it is released, is it possible?
    Posted Jul 04, 2019 06:48 PM
    Not yet, it is a fresh story. Where can I report it, should I open a TAC case?
    I know that article about releases, that's why I'm worried: Releases will typically take ~3-6 months to earn the Conservative tag.
    8.3.0.7 becomes CR in less than a month... (with 16 pages of known issues)
  • 4.  RE: AOS 8.3.0.7 becomes to CR 3 weeks after it is released, is it possible?
    Posted Jul 05, 2019 02:57 AM
    What I had understood from our SE is that train bugreleases, like 8.3.0.6, 8.3.0.7 etc. will only contain bug fixes and that ones engineering/support feel a release is stable for production it will marked as CR candidate.
    So the way I look at it is that 8.3 has been released since 29/06/2018 and the CR has been released on 24/05/2019, which is 11 months after the original train release.
    I'm not part of HPE/Aruba so perhaps an internal / PLM can explain it better or add some nuance.
  • 5.  RE: AOS 8.3.0.7 becomes to CR 3 weeks after it is released, is it possible?
    Posted Jul 05, 2019 09:55 AM
    It doesn't get fixed unless it is reported, replicated in-house and then patched.  You should open a TAC case and report it.
    The post above explains why it is not less than a month.
