I'm trying to use one of my outdoor AP-377s as a mesh portal. The mesh point I configured will not connect to it.
I have this working successfully on an AP-315 with the same exact settings and the same exact mesh point AP.
Below is what I get when I run show ap mesh active:
Mesh Cluster Name: Library Tents
Name Group IP Address BSSID Band/Ch/EIRP/MaxEIRP MTU Enet Ports Mesh Role Parent #Children AP Type Uptime
00-Mesh-Portal-Test Mesh xxx.xxxx.xx.xxx 80:8d:b7:ae:d6:30 802.11a/48E/21.0/31.5 1300 - Portal - 0 315 3m:29s
IT-TechSvcs-Outdoor Mesh xxx.xxx.xxx.xx 24:62:ce:ce:db:50 802.11a/157+/0.0/0.0 1500 Off/Off Portal - 0 377 1d:18h:43m:40s
Total APs :2
For some reason it says the EIRP and MaxEIRP are 0.0 on the 377.
When I do a show ap radio-summary for that AP, I get the following:
(Falcon) [MDC] *#show ap radio-summary ap-name IT-TechSvcs-Outdoor
APs Radios information
Name Group AP Type IP Address Band Mode EIRP/MaxEIRP NF/U/I TD TM TC
IT-TechSvcs-Outdoor Mesh 377 xxx.xxx.xxx.xx 2.4 AP:HT:11 11.0/31.3 -94/21/6 0/0/0/0/0/0 0/0/0/0/0/0 0/0/0/0/0/0
IT-TechSvcs-Outdoor Mesh 377 xxx.xxx.xxx.xx 5 MPP:VHT:157+ 19.0/36.0 -94/12/0 0/0/0/0/0/0 0/0/0/0/0/0 0/0/0/0/0/0
