For some reason ap's at our customers mobility controller won't choose channels under 100Mhz when they are set at automatic channel. At all regulatory domains channels 36-64 are allowed. If we disable 100Mhz -> channels from arm we get "
No valid channels; entering air monitor mode." Error.
What makes this case even more weird is that we have another ap-group at the same mobility controller. AP's at that group can use channels under 100Mhz.
So the guestion is what config option enables this kind of behavior for ap's.
