AP207
  • 1.  AP207
    Posted Nov 21, 2019 08:29 AM
    I need to connect 207AP to AOS8.5 running Controller, Rlease Note says it support 207AP but it not discover the AP, Is there any way to add 207AP to AOS8.5 running Controller?
  • 2.  RE: AP207
    MVP EXPERT
    Posted Nov 21, 2019 09:06 AM
    What Master Discovery configuration do you have in your environment?
    https://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Content/ArubaFrameStyles/AP_Config/AP_discovery_ADP.htm
    Failing this, do you have Control Plane Security enabled? Is the AP added to the whitelist?
  • 3.  RE: AP207
    On the commandline of the controller, type "show log system 50" to see if there are any errors.
