In Airwave, all APs in a site folder show "Error" under the Configuration column. When I select an AP and check the manage page, this error shows on the "Configuration:" item:
Error (Telnet/SSH Error: (pattern match timed-out) in password failure: Permission denied, please try again. )
Where do I set these credentials? In the controller configuration? Is so where? We are running three instances of Airwave. Instances 1 & 2 do not have this problem. Instance 3 does. There are multiple controllers per instance, yet instance 3 is the only one that has this problem.
