Re: ARP problems after connection
Were you able to open a TAC case?  Did anything come from it?  I am having the same issues on the same code version.  Thanks for any help you can provide.
Contributor I
No, I did not open a TAC Case for this. We had to fresh install of the system for some other reasons and since then we haven't had a lot of reports regarding this issue. Only one client with a self-complied Linux OS is experiencing this kind of problems.
If you open a TAC case for this, please let us know what your resolution was.
When you reinstalled did you reinstall 8.3.0.6 or a different version?
