Dear Arubers,
I try to define which deployment mode I have to use for my wireless architecture and I don’t really understand all the differences between each mode.
I’ve read this page : https://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/Remote_AP.php#XREF_52676_Fallback_Mode
But I’m not sure about the mode to choose.
I want an access point which :
- Is still working even if the controller is down.
- Can provide more than 1 SSD (one "corporate SSID" with central DHCP and one "Guest SSID" with local DHCP)
Could you help me to find the right deployment method ?
For « corporate SSID » i think « tunnel forward » is the right VAP profile mode, isn't it ?
On the other side, what is the solution for the « Guest SSID » : Bridge (always or persistent mode) ? Split-tunnel mode ?
I really thank you for the help.
