Re: Application Works on Wired Network but not on Wireless Network
rwilsonblue,
There are so many ways to set it up, that I'm not sure anyone can guess what your situation is.  We didn't know you were doing IAP-VPN.  Please keep us up to date on how it is progressing with TAC.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Frequent Contributor II
When I started this thread, I didn't think about this device being on the same network as an IAP. As we worked with TAC on it, they were able to see the IAP configuration is causing the issue. We have it working by allowing UDP 7700 on the logon role, at least from a Windows laptop. IOS devices are not able to connect and I'm starting to debug that now.
Running show datapath session table <clientip> on the mobile device's IP shows flags FDYC, just like we were seeing before, except the protocol was 6 instead of 17. Adding TCP/7700 to the logon role got the mobile devices working.
I'm going to consult with some folks to see if the way we are using the IAPs is the best scenario.
Robert
Adding a bit more info, another location has a RAP and it had the same issue.
