Aruba 515 stuck on 802.3af
Hi
We are in the process of setting up Aruba.
I'm setting this up at the moment and I'm finding the 515 access points will only use 802.3af POE instead of POE+.
We are using Cisco 9300-48P which does have POE+ (Its not full UPOE), but I was told that these should all work with these.
Are there any settings that I have missed so that these are not working on power save mode?
Re: Aruba 515 stuck on 802.3af
Do you have LLDP configured on that Cisco port?  That is how it communicates increased power.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Thanks, this is now working correctly
