MVP Expert
Re: Aruba AP-104 and AP-ANT-19 Antenna
For our installations, the AP275 is proving somewhat cheaper than AP104+cable+converter+external antenna+NEMA enclosure+heater+power cabling+etc.
If you're still planning the purchase, I recommend you look at the 275.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
