Hi
I am new to Aruba and need to design for an environment where AP-135s are already installed. These units are end-of-sale and end-of-support by Aug 01, 2020.
I want to understand what are the design implicaitons (from RF coverage and functionality point of view) down the road. For example, if we need to replace any of the existing Aruba APs (AP-135) with model AP-315 or later.
In my view the functionality of the system should be determined by the lowest common denominator (in this case AP-135) i.e. AP-315 should act as AP-135 (may be we need to disable few features on it).
It would be great if there is matrix available where I can see which APs can co-exists in an environment.
Even if co-exists but I would like to know what are recommendations/guide-lines.
Ghaz
