Hi!
Does anyone know any issue with Aruba Controller 7005 + ArubaOS 8.5.x and trying to join the controller to MM. I using full-config option and writing all parameters as always, but when the controller reboots it returns to the default initial state? it didn't try to contact the MM, just return to the following:
does anyone knows?
See if the cfgfile variable was set for some reason: https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-use-the-controller-boot-parameter-cfgfile-to-recover/ta-p/177922
You are right, the controllers has the cfgfile=default.cfg variable configured to another file, and also has a lot of "static" configuration in other variables.
I did a purgeenv and everything is working right now.
thanks
My 7005 MC didn't boot correctly by starting the ZTP but instead it is initializing GSM, CCM and FPAPP as below
do you know why?
Hi As per issue I can see you are trying via ZTP method. Can you try with manual method to add MC to MM or follow below or above link as per CJ
The ZTP screen always comes up before you are allowed to choose other methods. That does not mean the poster is trying ZTP. This issue happens usually when users set the cfgfile environment variable to something besides default.cfg but they don't set it back.
Hi
