last person joined: 7 hours ago
Aruba Controller - Internal Captive Potal with ClearPass as authentication server
  • 1.  Aruba Controller - Internal Captive Potal with ClearPass as authentication server
    Posted Mar 04, 2020 03:44 AM
    Hi community
    Can somebody confirm (or not):
    Is it possible to use internal captive portal built in controller altogether with ClearPass as radius authentication server ?
    In GUI there is option as follows:
    Internal Captive Portal with authentication
    but there's no option to set authentication server ?
    If someone have example and can share I wiil be happy
    Regards
    Karol
  • 2.  RE: Aruba Controller - Internal Captive Potal with ClearPass as authentication server
    Posted Mar 04, 2020 05:55 AM
    Yeah it should.
    But thats not the normal approach..why not use ClearPass for Captive Portal ? Its much better I think
    Okay, sorry I was just curious
    Just go to: Authentication --> L3 Authentication --> Captive Portal Authentication --> YOUR PROFILE
    And change the Server Group.
    That might work, but I have not tested this.
    Regards
  • 3.  RE: Aruba Controller - Internal Captive Potal with ClearPass as authentication server
    Posted Mar 04, 2020 05:59 AM
    Yes, that is possible, but not within the wizard.
    Create the WLAN via the wizard and than you have to configure a new AAA Profile for that WLAN VAP.
    Go to the right top corner - "admin" - "Preferences" - set the hook to show advanced Options
    Than go to the WLAN SSID - right hand "Profiles" - ... - AAA and set the ClearPass AAA Profile.
    This has to be configured beforehand if not already done.
  • 4.  RE: Aruba Controller - Internal Captive Potal with ClearPass as authentication server
    Posted Mar 04, 2020 06:46 AM
    Hi
    Thanks for all posts
    Yes I have tested it and it works
    Thanks for help
    Karol
