I'm trying to config syslog on Aruba controller AOS 8 in order to view syslog meaages on Solarwinds server.
is there any particular port to be used ?
By default it sends output on the standard port 514 if you do not specify. It should be the same on Solarwinds... unless I am wrong.
thank you,
indeed, it's using port 514, now I can see traffic with wireshark and also on Solarwinds.
One more question, it is possible to select at the 'logging level' tab more than 1 option ? I mean, informational and critical for example.
