ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
This thread has been viewed 23 times
  • 1.  ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted Jan 15, 2019 08:51 AM
    This post is about configuring the Controller for Virtual Intranet Access.
    Included information on 'where in GUI' and the equivalent 'CLI command'.
    Setup:
    Aruba7005 Controller in standalone mode running ArubaOS Version 8.3.0.5.VIA Setup.jpgVIA configuration requires that you first configure VPN settings and then configure VIA settings.
    VPN Settings:
    Enable VPN Server Module
    You must install the PEFV license to configure and assign user roles.
    GUI:
    Mobility Controller -> Configuration -> System -> Licensing -> Inventory -> Click on + sign and add the license.VIA License.jpg
     CLI:
    license add <key>
    Decide IKE Policy
    ArubaOS support both IKEv1 and IKEv2 protocol to establish IPsec tunnels.
    We will be using predefined default IKE policies "20", which has the following parameters, to establish the VPN tunnel.
    Encryption: AES256
    HASH: SHA
    AUTHENTICATION: pre-shared
    Diffie Hellman Group: 2
    GUI:
    Configuration -> Services -> VPN -> IKEv1 -> IKEv1 Policies
    Configuring the shared secrets
    GUI:
    Configurations -> Services -> VPN -> Shared Secrets -> IKE Shared Secrets
    CLI:
    crypto isakmp key  ****** address 0.0.0.0 netmask 0.0.0.0
    Address Pool
    Define the pool from which the clients are assigned addresses.
    GUI
    Configuration -> Services -> VPN -> General VPN -> Address PoolAddress Pool.jpg
    CLI:
    ip local pool via 2.2.2.2 2.2.2.200
    Define the DNS Server
    Configure the IP addresses of the DNS servers that is pushed to the VPN client.
    GUI
    Configurations -> Services -> VPN -> General VPN -> Primary DNS Server
    CLI:
    vpdn group l2tp client configuration dns 8.8.8.8
    Enabling NAT-T
    NAT traversal allows systems behind NATs to request and establish secure connections on demand.
    GUI:
    Configurations -> Services -> VPN -> General VPN -> Enable NAT-T
    CLI:
    crypto isakmp udpencap-behind-natdevice
    VIA Settings:
    VIA Authentication
    Create an authentication profile to authenticate users against a server group.
    GUI:
    Configuration -> Authentication -> L3 Authentication -> VIA Authentication -> Add a new profile and set the server group to 'internal'.Auth Profile.jpg
    CLI:
    aaa authentication via auth-profile "kapvia"
    server-group "internal"
    Adding local users:
    GUI:
    Goto Configuration -> Authentication -> Auth Servers
    In 'Server Groups' -> Internal.
    Click on 'Internal' and goto 'Users'
    Add local user here.
     CLI:
    local-userdb add username kapil password ******  role default-via-role
    VIA Web Authentication
    Create the VIA web authentication which is a list of VIA authentication profiles.
    The web authentication list allows the users to login to the VIA download page <https://<controller IP address>/via> to download the VIA client.
    GUI:
    Configuration -> Authentication -> L3 Authentication -> VIA Web Authentication -> Add a new web auth profile
    CLI:
    aaa authentication via web-auth "default"
    auth-profile "kapvia" position 1
    VIA Connection profile
    Create the VIA connection profile which is a collection of all the configurations required by a VIA client to establish a secure IPsec connection to the controller.
    A VIA connection profile is always associated to a user role, and all users that belong to that role use the configured settings.
    When a user authenticates successfully to a server in an authentication profile, the VIA client downloads the VIA connection profile that is attached to the role assigned to that user.
    GUI:
    Configuration -> Authentication -> L3 Authentication -> VIA Connection -> Add a new connection profile
    - Define the Server address
    - Link the VIA Auth profile
    - Mention the internal address that needs to be accessed by VIA
    - Enable split tunneling
    - Select the IKE Policy
    CLI:
    aaa authentication via connection-profile "kap-con-via"
    server addr "59.167.xx.xxx" internal-ip 10.10.101.1 desc "Aruba7005-Gateway" position 1
    tunnel address 192.168.17.0 netmask 255.255.255.0
    tunnel address 192.168.26.0 netmask 255.255.255.0
    tunnel address 172.30.30.0 netmask 255.255.255.0
    tunnel address 172.30.29.0 netmask 255.255.255.0
    tunnel address 172.30.20.0 netmask 255.255.255.0
    tunnel address 10.10.100.0 netmask 255.255.255.0
    tunnel address 10.10.101.0 netmask 255.255.255.0
    split-tunneling
    ikev2-policy "10004"
    ike-policy "20"
    no windows-credentials
    no domain-pre-connect
    Create VIA roles:
    Link the Address Pools and Connection Profile
    GUI:
    Configuration -> Roles & Policies -> Roles -> Modify the 'default-via-role'
    CLI:
    user-role default-via-role
    pool l2tp via
    via "kap-con-via"
    access-list session global-sacl
    access-list session apprf-default-via-role-sacl
    access-list session allowall
    access-list session v6-allowall
    Verification Commands:
    show crypto isakmp sa
    show crypto ipsec sa
    Hope you find this post useful. Please post your feedback.
    Kapildev Erampu
  • 2.  RE: ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted May 01, 2019 03:28 PM
    It's my understanding that the VIA pool must be routable. Is that not the case?
  • 3.  RE: ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted May 01, 2019 04:12 PM
    Not at all.  You would have to have a any any any src-nat ACL at the bottom of the client firewall policies, is all for that client to be able to pass traffic.
  • 4.  RE: ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted Apr 10, 2020 03:19 AM
    Hi CJoseph,
    1.Is enabling source national on pool itself is enough to avoid routable pool.
     2.let me know that enable src nat acl in client firewall policy, you mean in user role.?
    3.Do we need  to do destination nat on firewall to allow client traffic to controller.
    Mallikarjun
  • 5.  RE: ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted Apr 10, 2020 09:31 AM
    @Mallikarjun Hiremath wrote:
    Hi CJoseph,
    Mallikarjun
    1.  Enabling source nat as a checkbox under the pool creates a srcnat acl and applies it to the default-vpn-role.  If your VIA clients are not using the default-vpn-role, source natting will not work for them.  You should create your own acl that source-nats all traffic and put it at the bottom of your VIA user role (you can also make it the only acl in your user role).
    2.  Yes.
    3.  You do not.  If your pool is non-routable and the acl is source-natting traffic, you don't need to do anything.  If your pool is routable, it should be in a subnet on an ip interface that already exists on the physical controller.  That should just work.
  • 6.  RE: ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted Apr 10, 2020 11:18 AM
    Hi CJoseph,
    Thank you for the response.
    3.I mean when the VIA CLIENT accessing the network when the firewall comes between the controller and the user ( via client) .
    4.How many PEFV Licenses we need to have for 100 users.
    5.What is the number of VIA TUNNEL limitations for the controller.
    Mallikarjun
  • 7.  RE: ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted Apr 10, 2020 11:42 AM
    3.  If traffic is source-natted, the client traffic will appear to come from the uplink ip address of the Aruba Controller
    4.  Please take a look at the website here:  https://www.arubanetworks.com/techdocs/VIA/3x/content/via%20config/before_you_begin.htm?Highlight=licensing
    5.  Each VIA client consumes an ipsec tunnel.  IPSEC tunnel limits for the 7000 series controllers are here:  https://www.arubanetworks.com/assets/ds/DS_7000Series.pdf
  • 8.  RE: ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted Apr 14, 2020 06:24 AM
    Thank you.
    Mallikarjun
  • 9.  RE: ArubaOS 8 - Quickly configuring the Controller for Virtual Intranet Access (VIA)
    Posted Apr 10, 2020 04:11 AM
    It depends on your use case...
    If the traffic will only be initiated from the VIA clients and you don't need to see the real VIA client IP on your "corporate network" then there is no need to have routable VIA client IPs. Natting the traffic will work.
    However, if you need to reach the VIA clients directly from your "corporate network", meaning traffic will be initiated from your network to the VIA clients IPs, then yes the VIA client IPs need to be routable.
    I use this for example when I use my VIA client machine as the SFTP/TFTP server. The "switch" in my "network" will initiate the TFTP/SFTP to my VIA client machine so in this case it should be routable. Note the role policy should allow traffic initiated from corporate to reach the VIA clients as well..
