Branch controller tunnel inside a 3rd party IPSEC tunnel
I want to add a branch 7008 controller that is managed by my VMM in HQ (both running AOS 8). The Branch and HQ use a 3rd party firewall with an IPSec tunnel to connect the sites. I do not want to try and setup a tunnel from the branch controller to a VPNC in HQ.  Is is possible to setup the controller IPsec tunnel between the MD and the MM inside of a 3rd party IPsec tunnel?Capture.JPG
Re: Branch controller tunnel inside a 3rd party IPSEC tunnel
hi cb732,
from my point of view, if there is IP connectivity between the 7008 and the MM in your HQ, they will connect as they were on the same campus.
I do not see any problems with this setup.
BR
Florian
visit our Youtube Channel:
https://www.youtube.com/channel/UCFJCnuXFGfEbwEzfcgU_ERQ/featured
Please visit my personal blog as well:
https://www.flomain.de
