Highlighted
Occasional Contributor I
Build String Mismatch - VLAN
Hi All,
We currently have an error on our 7210 controllers running Aruba 8.3.0
Build String Mismatch - Image attached.
From what i first initially understand this is caused by a mismatch of VLAN's, the 160 VLAN in this situation is on both controllers. what else could be causing this error message?
Robert
Accepted Solutions
Highlighted
Re: Build String Mismatch - VLAN
this was an old error from when the controllers were rebooted during firmware upgrades. a reboot resolved the error but HPE support first got us to get the cluster into L2 mode as it was currently in L3 with the previous error.
View solution in original post
All Replies
Highlighted
All of the controllers in a cluster need to be running the exact same version of ArubaOS.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
Highlighted
Thanks for the reply, both controllers are running ArubaOS 8.3.0.3.
image attached of #show version, same on both controllers.
Highlighted
