Hi community
I have a problem in my controller
when i try to take a backup flash this message shows uperror Backing up DBs..May have run out of space.
I tried to remove unwanted files but the error appears
Type "tar crash" to see if it creates a crash.tar file. If it does, delete the crash.tar file and try again.
I tried this command and no crash was found
the problem still exists.
You probably have to open a case with TAC. There could be a hidden file that is taking up alot of space, that you don't have access to.
