I am implementing an AOS8 project. I encountered a channel bandwidth problem during the implementation process. I hope that the 5Ghz radio uses 40Mhz bandwidth. The vaild channel settings in my corresponding AP Group are as follows:
On the mobility master ,I also executed the command airmatch runnow quick.
Excuted the command show airmatch optimization and show airmathc solution output as follows:
Execute show ap active and find that the AP always runs at 80Mhz bandwidth.
Is it the configuration I missed? Can someone help me?
