Hi
I was looking for doing some kind of preconfiguration. So i wrote some simple script for building a CLI command list. With this list I created whitelist entries for APs. (I scanned the mac adresses from the boxes).
First of all it looked good.
After installation APs came up with the correct group.
But now if I want to reconfigure the APs and move them to another group it is not possible via AP provisioning any more.
I try to delete the whitelist db entries but there is no effect. APs boot an come up with same old AP group. No matter if I reprovision the AP.
So for final solution i have to modify the whitlist entry. For lots of APs that is not handy. As second problem no i have serveral APs which I have to configure in whitelist and lots of APs which I have to configure via provisioning.
Is there a way to clean whitelist completly?
For my experience the whitelist config is stored on the AP too, because after deleting the AP from whitelist after rebooting the ap the whitelist entry is there again.
I am using AOS 6.5, CPsec with autolearning is active.
