last person joined: 7 hours ago
EIRP won't increase
  • 1.  EIRP won't increase
    Posted Jan 28, 2019 08:05 PM
    Im running a 7005 controller with a single AP-335 for my home lab.  I'm running AOS 8.2.2.3 and the controller is standalone (no Mobility Master).  Nothing I seem to do seems to actually increase the EIRP though, it's almost like it's locked in place.  Using both the GUI and CLI to modify the Radio Profiles, I've been trying to just set the EIRP to Max, but there is no change to the AP transmit power:
    # show ap radio-summary
    APs Radios information ---------------------- Name Group AP Type IP Address Band Mode EIRP/MaxEIRP NF/U/I TD TM TC ---- ----- ------- ---------- ---- ---- ------------ ------ -- -- -- ap01.office default 335 192.168.1.130 2.4 AP:HT:6 16.6/16.6 -96/33/7 71/83/81/66/81/75 28/8/9/22/9/16 0/8/9/11/9/8 ap01.office default 335 192.168.1.130 5 AP:VHT:48E 17.5/17.5 -92/2/0 0/0/100/0/0/0 0/0/0/0/0/0 0/0/0/0/0/0
    Here's the relevant portion of the running config:
    rf arm-profile "default-a"
        min-tx-power 127
    rf arm-profile "default-g"
        min-tx-power 127
        free-channel-index 40
    rf arm-profile "default_radio_a_ui_arm_a_ui"
        min-tx-power 127
    rf arm-profile "default_radio_g_ui_arm_g_ui"
        min-tx-power 127
    rf dot11a-radio-profile "default_radio_a_ui"
        am-scan-profile "default_radio_a_ui_amscan_a_ui"
        eirp-min 127
        eirp-max 127
    rf dot11g-radio-profile "default_radio_g_ui"
        am-scan-profile "default_radio_g_ui_amscan_g_ui"
        eirp-min 127
        eirp-max 127
    What am I missing?
  • 2.  RE: EIRP won't increase
    Posted Jan 28, 2019 08:41 PM
    The max regulatory EIRP for that AP for an 80mhz channel on channel 48  is 17.5.  you are already at 17.5, which is the limit.
  • 3.  RE: EIRP won't increase
    Posted Jan 28, 2019 08:44 PM
    Run this command:
    show ap debug power-table ap-name <name of ap> radio 0
    That will tell you the maximum transmit power for 20/40/80mhz wide bands on each channel for that access point in your current regulatory domain.
  • 4.  RE: EIRP won't increase
    Posted Jan 28, 2019 08:59 PM
    Here's the output:
    #show ap debug power-table ap-name ap01.office radio 0
    Channel 48
    Bandwidth:80Mhz
    Actual Antenna Gain: 2.5
    Connector loss: 0.0
    Effective Antenna Gain: 2.5
    Override board limit: 15.0
    Antenna Polarization: Cross Polarized
    Number of Active Chains 1
    User Configured Power(EIRP, dBm) 18.0
    Min Power(EIRP, dBm) 2.5
    Min Power (Conducted, dBm) 0.0
    Effective User Configured Power (EIRP, dBm) for current active chains 18.0
    Effective User Configured Power (Conducted, dBm) for current active chains 15.5
    I'm trying 40 MHz channels to see if that'll increase it
  • 5.  RE: EIRP won't increase
    Posted Jan 28, 2019 09:54 PM
    The radio-summary output already has the max:
    Looking at the power table says what the max would be on other channels, but it is not  more than 18, on any channel/width combination.
  • 6.  RE: EIRP won't increase
    Posted Jan 28, 2019 10:08 PM
    Well that's very very important to know.  I was looking at replacing our 325s, but with the max power that much lower, it may be worth revisiting this plan.  Thanks for the help
  • 7.  RE: EIRP won't increase
    Posted Jan 28, 2019 10:21 PM
    It all depends on what you are trying to with with that access point.  What is the environment that you are trying to support?
  • 8.  RE: EIRP won't increase
    Posted Jan 28, 2019 10:43 PM
    What requirement is not satisfied by your 325s, that you would consider 335s?
