Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Re: Fast-Failover in VRRP setup
You can use either one, in that scenario.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
View solution in original post
Highlighted
Contributor II
Thanks for the reply.
When you say either one, do you mean use VRRP - OR - use HA Fast Failover as failover mechanism.
I'm trying to figure out if there's an advantage in running both simultaniously?
Highlighted
Yes.
There is no significant advantage to running them simultaneously if you are using master/backup master (standby) and you are already pointing access points to the VRRP.
Highlighted
Occasional Contributor I
Well, Configuring APFF in addition to VRRP on Master Active/Standby will help in the situation where you have many APs and you need them to smoothly moving from the Active to Standby at the time of failure. With APFF and HA the APs will create two IPSec/GRE tunnels to the Active and Standby controllers that help the APs to imidiatly switch to the standby controller (Less delay time).
Highlighted
The standby controller will not be able to service clients until it has control of the VRRP.  If the access points fail over before the VRRP is switched, the clients on those access points will not be able to do anything.
It is best to just deploy APS pointing to a VRRP between master/standby.  For any other relationship, fast failover will work just fine.
