last person joined: 8 hours ago
Firmware versions difference between MM and MC
  • 1.  Firmware versions difference between MM and MC
    Posted Jul 11, 2018 12:25 PM
    Does Aruba have any best practices when it comes to the version of the MM and its controllers?
    For exaple: Are the Mobility Controllers allowed to be on a higher firmware(8.2.1.1) than the Mobility Master(8.2.1.0)?
  • 2.  RE: Firmware versions difference between MM and MC
    Posted Jul 11, 2018 12:29 PM
    The MM should have a higher version (recommended) than the MCs
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Firmware versions difference between MM and MC
    Posted Jul 11, 2018 03:57 PM
    The MM should be the same or a higher version than the MC's/VMC's.
    The MC's/VMC's can never have a higer version then the MM.
    So this means that when upgrading always upgrade the MM first!
    Hope it helps.
