Hi there,
I am having trouble setting up my guest WIFI on my MSM760.
I have set up a guest SSID that uses HTML based logins. This works totally fine, however all traffic on my proxy shows as the MSM760's internet port IP address.
I would like this so i can see the IP address that is associated with the device. So we can track web filtering on our proxy.
Current setup:
Interfaces: Internet port IP: 10.10.1.15 mask 255.255.0.0
LAN port IP: 10.140.1.1 mask 255.255.0.0
Guest VLAN: 140
DHCP server config (on the MSM)
IP: 10.140.0.1 - 10.140.11.184
GW 10.140.1.1.
I believe this is a problem on the NAT on the interner interface, but i cant seem to get internet once i untick this. Any help would be great!
Thanks.
