Hello!
A customer of mine got a HUAWEI E3372h and a AP-203r which he want to terminat as RAP on a 7205 controller pair under AOS 8.3.0.4.
Everything works fine until we want to provision the RAP with a USB-Profile.
Environment:
2x 7205 (Master/Backup)
ap-203r
AOS 8.3.0.4
ISP: A1 (Austria)
APN Details providet by ISP
APN Details providet by community
1st Problem
As soon as a USB-Profile is tied to the RAP AP-Group, the RAP will no loger set up a IPSEC tunnel over the eth0 uplink, regardless if the LTE stick is connected to the RAP or not.
2nd Problem
The LTE stick will not dial up to the ISP.
We tried two sets of configuration for the USB Profile, like recommendet in this two topics:
1. 4G/LTE Modems Zentral Europa
2. Konfiguracja AOS pod modem Huawei E3372h
USB Profile 1:
USB Device Type: huawei-cdc
USB Device Identifier: 0x12d11f01
USB Dial String: ATD*99#
USB Initialization String: AT+CGDCONT=1,\"IP\",\"A1.net\"
USB TTY device data path: N/A
USB Profile 2:
USB Device Identifier: 0x12d11506
USB Dial String: N/A
USB Initialization String: AT+CGDCONT=1,"IP","A1.net"
USB TTY device data path: ttyUSB0
I described the settings in a deeper detail in the german community.
Does anybody has made some experience with the HUAWEI E3372h and a rap-203r?
Thank you!
