How can i check MSS on aruba wireless
  • 1.  How can i check MSS on aruba wireless
    Posted May 08, 2020 05:18 AM
    Hi everyone
    How can i check MSS on aruba wireless?
  • 2.  RE: How can i check MSS on aruba wireless
    Posted May 09, 2020 03:24 PM
    How can i check MSS?
  • 3.  RE: How can i check MSS on aruba wireless
    Posted May 09, 2020 04:17 PM
    I don't think you can control MSS but can only control MTU.. What are you trying to check or achieve?
  • 4.  RE: How can i check MSS on aruba wireless
    Posted May 10, 2020 02:49 AM
    Hi
    I have a problem some video application. Ex.Microsoft team , Cisco webex . The problem is occured  when using video in app.
  • 5.  RE: How can i check MSS on aruba wireless
    Posted May 12, 2020 02:38 PM
    MSS is not configurable on the system outside of PPPoE which you probably aren't dealing with, you can see the negotiated MSS with a packet capture and looking at the TCP SYN packet during the TCP handshake for a session.
    The only scenario I can think of where MSS would be impacting you like this would be if the MSS is negotiated to a value that the GRE tunnel back to the controller (assuming tunneled) can't support, that would point back to MTU issues in the network that could be adjusted. Could also just as easily be jitter, channel busy, and solar flares.
