Hi All,
First of all, apologies if I am repeating a common question. I just gone my hand on some AP105s and I am trying to figure out what to do to get them running.
How do I tell if I have a AP-105 or IAP-105? One of my units can be accessed via HTTPS and I can manage it via the Virtual Controllers. The other two however, get an IP address but that is as far as they go. I tried resetting them but no luck either. They all look identical from the outside.
The next question is, can I download a controller software from some place to use the AP-105s?
Can the IAP-105 virtual controller manager the AP-105?
Thanks in advance.
Vin
