IAP 205 not joining iap 315 cluster
  • 1.  IAP 205 not joining iap 315 cluster
    Posted Sep 04, 2018 11:35 PM
    Please help what are the things i need to do if IAP 205 is not joining iap 315 cluster? Thank you!
  • 2.  RE: IAP 205 not joining iap 315 cluster
    Posted Sep 05, 2018 12:03 AM
    Make sure both access points have access to the internet.
  • 3.  RE: IAP 205 not joining iap 315 cluster
    Posted Sep 05, 2018 02:24 PM
    After connecting all the access points to the internet still am unable to fix this problem. Thanks in advance for your help. Thanks and Regards, panda helper app emu4ios app gbwhatsapp app
  • 4.  RE: IAP 205 not joining iap 315 cluster
    Posted Sep 05, 2018 08:53 PM
    Access point 205 is reachable via icmp but not accessible thru cli. It is also connected thru internet. Happened after firmware update thru aruba central said our client.
  • 5.  RE: IAP 205 not joining iap 315 cluster
    MVP EXPERT
    Posted Sep 06, 2018 01:45 AM
    So this 205 is managed via Central correct? Do you see the 205 as it’s own cluster in Central? Have you tried acessing the console?
    Do you have auto-join enabled on your cluster?
  • 6.  RE: IAP 205 not joining iap 315 cluster
    Posted Sep 06, 2018 01:51 AM
    205 is managed in central. AP is in remote site they haven't tried accessing it thru console. How can we turn on auto join. IAP 205 is not accessible after reboot.
  • 7.  RE: IAP 205 not joining iap 315 cluster
    MVP EXPERT
    Posted Sep 06, 2018 03:43 AM
    Under Central :
    Wireless Management -> System -> General -> Auto Join
    I suspect the 315 has a latter firmware then the 205. They will need the same level of firmware in order to create a cluster. Whether this image upgrade occurs locally or via the internet.
