@cjoseph wrote:
We would need the tech support from the VC to understand what could be the problem.
How often does this happen?
Can you take a screenshot of the error?
Does it eventually fix itself or do you have to do anything manually to fix it?
Can you get the tech support of the VC?
@hey @cjoseph, sorry for the late reply, about your questions,
-the problem happens at various times, sometimes every 3 hours, or a few days after
-everytime the AP reboot, it operates normally again, but after moments later, the problem comes again
-here's the tech support of the VC
