We are seeing performance issues with our wireless network. Mostly around slow speeds as well as dropped connections. If I do a
show ap arm state ap-name command on an access point I'm getting the following results. To me, it seems like the AP is seeing too many other APs.
AP:Hussey-Room-205 MAC:90:4c:81:f5:4c:20 Channel:1 EIRP:6.5 Max EIRP:24.5 Edge:disable
Client Density:0 Valid neighbors: 25 Relevant neighbors: 13 Rx Probe Reports: 16833
Moves(T/S):5/1 Sticky(T/S):0/0 Bandsteer(T/S):5/1 Loadbal(T/S):0/0
Neighbor Data
Name IP Address SNR (dB) Path Loss (dB) Channel/Pwr Neighbor Density Neighbors (R/T) Relevant
Hussey-Room-202 172.20.5.74 20 82 1/6.5 0 12/21 Yes
Hussey-Room-206 172.20.4.238 30 71 6/6.5 0 9/20 Yes
Hussey-Room-201 172.20.6.216 30 70 6/6.5 0 10/28 Yes
Hussey-Room-210 172.20.4.92 21 85 6/9.0 0 7/20 Yes
Hussey-Room-209 172.20.4.166 26 79 1/9.0 0 11/20 Yes
Hussey-Room-208 172.20.5.149 30 70 11/6.5 0 11/19 Yes
Hussey-Room-204 172.20.5.93 32 74 11/6.5 0 10/19 Yes
Hussey-Room-207 172.20.5.139 39 61 11/6.5 0 10/28 Yes
Hussey-Room-203 172.20.4.64 39 56 6/6.5 0 11/25 Yes
Hussey-Room-304 172.20.4.25 13 91 1/9.0 0 10/31
Hussey-Room-405 172.20.5.204 11 88 6/6.5 0 7/31 Yes
Hussey-Room-306 172.20.4.241 8 95 6/9.0 0 10/35
Hussey-Room-106 172.20.5.210 23 85 1/9.0 0 7/26 Yes
Hussey-Room-104 172.20.5.142 8 96 1/9.0 0 10/29
Hussey-Room-408 172.20.5.105 23 78 1/9.0 0 10/18 Yes
Hussey-Room-102 172.20.5.88 7 95 11/6.5 0 7/27
Hussey-Room-403 172.20.4.153 9 97 1/9.0 0 9/28
Hussey-Room-302 172.20.4.49 7 96 11/9.0 0 6/27
Hussey-Library 172.20.5.226 9 94 1/9.0 0 7/20
Hussey-Room-409 172.20.5.183 12 90 6/9.0 0 7/25
Hussey-Room-407 172.20.6.37 6 95 11/6.5 0 13/34
Hussey-Room-404 172.20.5.170 1 98 6/6.5 0 7/21
Hussey-Main-Office 172.20.6.84 7 86 6/9.0 0 4/23 Yes
Hussey-Room-406 172.20.6.235 5 100 11/6.5 0 10/23
Hussey-Hall-220 172.20.6.197 11 93 1/9.0 0 3/18
Legend: R = Relevant, T = Total, Neighbor Density = (Overlap/Neighbor's Density/ Overlap to local density ratio/ Overlap to neighbor's density ratio)
AP:Hussey-Room-205 MAC:90:4c:81:f5:4c:30 Channel:165 EIRP:18.0 Max EIRP:31.9 Edge:disable
Client Density:0 Valid neighbors: 17 Relevant neighbors: 6 Rx Probe Reports: 16833
Moves(T/S):0/0 Sticky(T/S):0/0 Bandsteer(T/S):0/0 Loadbal(T/S):0/0
Neighbor Data
Hussey-Room-209 172.20.4.166 22 97 153/18.0 0 6/12
Hussey-Room-208 172.20.5.149 24 84 36/15.0 0 5/11 Yes
Hussey-Room-202 172.20.5.74 23 94 149/18.0 0 3/13
Hussey-Room-206 172.20.4.238 34 84 48/18.0 0 6/11 Yes
Hussey-Room-201 172.20.6.216 31 84 40/18.0 0 5/15 Yes
Hussey-Room-203 172.20.4.64 45 63 157/18.0 0 4/13 Yes
Hussey-Room-210 172.20.4.92 20 101 161/18.0 0 5/12
Hussey-Room-207 172.20.5.139 34 73 36/15.0 0 4/15 Yes
Hussey-Room-204 172.20.5.93 32 79 44/18.0 0 4/8 Yes
Hussey-Room-304 172.20.4.25 8 102 44/18.0 0 4/13
Hussey-Room-409 172.20.5.183 10 105 149/18.0 0 3/17
Hussey-Room-405 172.20.5.204 10 100 157/18.0 0 4/15
Hussey-Room-306 172.20.4.241 9 100 36/18.0 0 4/17
Hussey-Room-407 172.20.6.37 8 103 40/18.0 0 1/16
Hussey-Library 172.20.5.226 8 102 157/18.0 0 1/9
Hussey-Room-410 172.20.5.154 5 109 165/18.0 0 3/10
Hussey-Room-104 172.20.5.142 7 102 44/18.0 0 3/12
